dwoodlock
So over the last 6 months or so I put together a chiller system for the presses at our facility. some of them use in-die cooling.
I am programming with an s7-1200 controller, g120c drive, and ktp1200 hmi.
The system when operational will have about 300gallon capacity.
Currently I have just been operating the cooling loop in the holding tank, to see how quickly it will cool.
Bare in mind, this is my first project like this, and I just kind of threw it together, and thus far it works pretty well.
Cooling loop consists of (Pump) - (rtd) - (air/water exchanger) - (rtd) - (liquid/liquid exchanger) - (rtd).
My initial belief when I put it together was that I would use the VFD to control the pump speed on the cooling loop based on what the post loop liquid temperature was.
If I needed more cooling, slow the flow, if I need less speed it up. Varying the flow ratio's to achieve my set point.
Since I started toying with the system, I basically wrote some quick code to give it a whirl, and honestly just toggling the valve on the liquid/liquid exchanger that enables the glycol flow seems to work pretty well.
Wondering if anyone with experience and can throw in their 2 cents on this as far as what method they would use to manipulate the liquid temperature. (vfd with the circulation pump OR what I'm guessing would be called PWM with the glycol valve??)
Thanks in advance.
Thanks in advance.
