pid heat exchanger for temperature regulation
JEANST
Jun 2015
PARIS
68
hello i would like some tips about pid regulating on hot water circuit with heat exchanger. i explain the context.
i have a primary water circuit with temperature between 100 - 105°C
this circuit is passing through a heat exchanger. an analog 3-way valve enable to modulate the water flow.
at the secondary circuit the temperature of water must be controlled (eg 70°C)
a temperature sensor gives a feedback to the PID controller to control the 3-way valve at the primary circuit. the amount of water i must heat is quite high (3000 l)
What i have observed is the system have a high delay before responding. and i have some over and undershoots a little bit more that i would like.
I have set a quite slow regulation with low P and high I , no D a the moment but i Wonder if it would not be better. if some D is necessary should it be high or low value ?
the question i have is how can i integrate this delay of reaction due to the system ? to have optimized parameters, with enough reactivity
any experience would be greatly appreciated
thanks
Hi, I’m a new member and I have a question about the PID function in a Micrologix 1400. I have 4 separate Heat Trace circuits that I need to...
3,782
I am trying to build ladder logic in rsl5k to turn on a contactor with a digital output. I have a 1769-IT6 input card and a 1769-OA16 output card...
1,952
I'm working on a project with a Micrologix 1400 with a temperature control PID block. The system has both heating and cooling, but the tricky...
3,664
88
Hello, I have a motor that we are sending a RPM Speed Output from 0-100% to the VFD. However, the Motor HP needs to be limited to 6000 HP and the...
92
