PID help
Mr. Ro Bot: The program you posted, is that the program that is giving you these odd numbers? (The whole program)
I didn't scale the input which is referencing a linear potentiometer that goes to 32k (roughly) so the 20k set ponit was roughly 2/3 extended (the desired position I want to maintain).
I tried a lower set point and had the same issue.
I'm having this issue regardless of the program.
I've written a few programs and had the same issue.
The one I linked to was just the most simplified version of it.
A simple move instruction. I don't know if it's just a Micrologix 1200 issue and I should try it on an SLC500 or what...I'm lost haha
You need to, just dont lower it... set it up as a engineered value, thats the easiest way, scale your input to something that you can understand like 0-100, it makes it a lot easier to understand
Hello all, I have an issue with a PID block in RsLogix 5000. The parameters are P: 3.25 I: 0.11 D: 0.01 The Set Point is 71 psi This loop...
63
14,831
I need a little help with a project I have been thinking about. We have a belt line that is fed by a gravity door (pretty much a hydraulic...
2,742
Hi all, I have a request from client as follows, There's one PID for Control valve which would be controlling on basis of temperature. One...
1,523
Hi, I am trying to automatically regulate a process ( liquid ) in a tube using an ultrasonic sensor, differential level meter, control valve...
3,156
Peter, I have been following all of your posts since 2009. We (PLCS.NET forum), are all amazed at your acquired empirical knowledge to identify a...
2,463
