Unity Pro Logic Help regarding PID Loop.
Jan 2016
Sharjah
20
Hi all,
I have a request from client as follows,
There's one PID for Control valve which would be controlling on basis of temperature. One setpoint should be entrered in Degree C from Local HMI, but the Remote Control wants to write the Setpoint in Fahrenheit. No Local/Remote selection button required by client on graphics.
Suppose if Setpoint in Fahrenheit changes then it moves to PID setpoint and convert the setpoint of Fahrenheit to Degree C and move it to setpoint C as well for local operator information. Same in case of If Setpoint Degree C changed by Operator then it moves to PID SP and convert the Degree C SP to Fahrenheit and move to Setpoint F.
This is confusing for me, I've tried many methods but didn't get it working. Need inputs from your side :)
Hello, I am on a project using Unity Pro S v6 and am trying to perform a time of day interrupt by reading the high and low bytes provided by the...
2,673
Hello I'm used to modicon PLC's and on my newest project i'm using a allenbradley. I usually use a custom DFB for my motors and conveyors...
4,125
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
179
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
404
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
716
