busarider29
Setting up a PID instruction to control the temperature of oil in a small tank. First time using PID instruction. The heaters are 480VAC energized from a solid state relay with 110 VAC coil. Following the instructions in the Logix500 instruction set manual, it has a small program for time proportional control on page 9-31 which I plan to implement in my program. Is the latching output in that program the direct output to the coil to my SSR? Should I be using an analog output address to energize the coil??
