dginbuffalo
Hello all- I'm looking for some guidance on the attached PIDE setup. What I need the valve to do is be open 100% when the system is not running. I'm accomplishing this by the SEL block. When stopped, it uses In2 and moves 20,000. When running (after a time delay) it switches to In1 and takes the PIDE signal. My main question is how do I get the PIDE to take over from the 20,000 reference? Will holding CVPrevious at 20,000 accomplish this? The PIDE is going to want to shut the valve because its under pressure, but I need to hold it open for a time to get a loadless start and I want to have a bumpless transfer. Any suggestions? I know there are a lot of was to skin this cat. Thanks ahead.
