buhnen
Hi!
I'm trying to understand how does work the PIDE autotuning feature and I've got good documented resources for it from the Rockwell library but when testing its functionality for real, on the work field, I'm yet finding some troubles.
For instance, I have to tune a PID for a level control process. I must keep a setpoint value, say 160 cm, for a the liquid level in a tank (the liquid is sewage waters). I've got a running flow into the tank which is not steady at all, but waving (not a big waving though) and causing disturbances to the system. So when trying to use the autotuning, I'd need to know first of all, WHEN, is the right moment for starting its execution...may it be in the exact moment when the level line is going up and it's near to the setpoint? for instance, when the level line is 1,40 going up getting closer to my setpoint of 160 cm?...or is it rather the opposite to this, this is, when the level line is going down?
I've made several attempts but a displayed error message popped up several times saying that the PV wasn't steady enough to keep on with the autotuning process, and of course, everytime I got this message, the autotuning execution got interrupted by itself....but I wonder, on the other hand, how is this possible because the flowing in of liquid will always be waving and there's nothing I can do about...
In a couple of occassions I didn't get that error message but the autotuning process seemed to last too long and it never got to be completed, just before the level line had reached the top of the tank.
I don't know either very well what should I do about these two parametres "PV change limits" and " CV Step Size". I've let the first one to zero and the second one to 10% as I could understand from reading the Rockwell manuals that it is well advised to start from small values ( I mean the CV Step Size) for the tuning.
Could I get any clues for you folks?
Thanks in advance.
Thanks in advance.
