PIDE Using Cascade Ratio Mode
remullis
Oct 2012
Georgia
179
I am attempting to use the Ratio Control of a PIDE. I have gone through publication wp-008A to setup the Ratio Control.
A little about the process:
I am mixing water and clay at almost 1/1( 50%) solids. I am controlling the water wiring it into PV to open and close CV which is my water valve. I am wiring the clay feed into SPcascade. I am then bringing my ratio which is 50% solids or .50 into my RatioProg.
We are running roughly 600 lbs of water into PV and 670 lbs of Clay per min into the SPCascade which I want to control by the ratio .50 or whatever the solids meter is reading at the time.
The problem I am seeing is the SP should reflect the SPcascade # X the ratio however it is no where close to that number significantly lower. My PVEU and SP Engineering units are set to 1000 respectively.
Any thoughts on what I am missing here. I have been on the phone with Rockwell with no resolve. Thanks Rich
I was able to get this PIDE Ratio to work after all. I was not taking my ratio .50 back to the right input on the PIDE. Thanks.
Hi All Is it wise to do pH control using PIDE with autotune? If yes can someone show me a code snippet on how to do the wiring in the function...
3,968
Hello all, we have an homogenizing oven with three zones, 2 burners in each zone, a soak (smaller) and a main (large). during ramp to the air...
147
Greetings ... someone sent me a request for some student handsouts that I developed ... turns out that I had this hosted on my business website...
140
Have a logix controller and I'm using the PIDE block for the autotuner. I've got the hang of doing it for direct control things like pressure...
21
1,783
Studio 5000 version 34. Have error on PIDE CVFaulted (Status1.2), Control variable (CV) health bad. No more information online or in...
976
