pilot
jadhiambo
Oct 2015
moyale
It is required to have a pilot light come on when all of the following circuit requirements are met:
* All four circuit pressure switches must be closed
* At least two out of three circuit limit switches must be closed
* The reset switch must not be closed
Using AND, OR, and NOT gates, design a logic circuit the will solve this hypothetical problem
Sounds like homework.
Some of us will help but only if you show your work and are willing to try to figure it out with help (as apposed to SOMEONE simply giving you the answer).
when it sys all 4... that would be a series cct. not parallel, any of the 4 would be parallel. also at least 2.of the 3 limit switches means you will need a series parallel setup after the pressure switches... does sound like homework and he did try something. hopefully this gives you some idea to try again
I was hoping to get a response from the OP, must be using the wrong bait.
Hello Guys, Can anyone share the Combined tube autopilot program If anybody worked with it.. we have newly installed this Auto pilot CT which is...
1,396
It is my understanding that an LED is considered a simple device, making its use fairly simple in an IS application. However I am running into a...
22
5,932
Has anyone gotten Modbus RTU to work with this HMI in any fashion? We've been hooking it to different PLCs and sensors. We've tried it in master...
1,414
I have an older vacuum convey system with a lot of enable / disable switches and pilot lights of every color. They appear to be an older and I...
3,113
Hi All, I have started a side project for the control on a table top scale, continuous chemical process for a startup (limited money). This...
4,056
