Pinout for RJ45 connector on Magelis for RS232
jjm5jjm5
Jun 2006
Taranaki
I am trying to conect a Magelis XBTG (touch screen) to a Qunatum over Modbus, using RS232.
The pinout in the Magelis manual is not clear (Maybe so I will buy a cable from Schneider), does anyone know the pinout between the 9 pin D connector on the Quantum and the Magelis.
The pinout for the Magelis is
02 RxD
03 TxD
04 DTR
05 SG
06 DSR
07 RTS
08 CTS
While the Quantum has
01 DTR
02 DSR
03 TxD
04 RxD
05 SG
06 RTS
07 CTS
08 -
You can build a serial cable by connecting
________[Magelis DB9]----------- [Quantum RJ45]
Connect___________02 RxD --------------- 03 TxD
Connect___________03 TxD --------------- 04 RxD
Connect___________05 SG ---------------- 05 SG
Jumper DTR/DSR____04,06__________________01,02
Jumper RTS/CTS____07,08__________________06,07
(By the way, www.rj485.com has an universal adapter that let you make this cable, or any cable that has DB-9F on one end and RJ45 on the other end)
Good luck.
Scadaman
Hello guys, I am trying to control a ATV12 via Modbus Poll software. I need the connection diagram for Altivar Modbus RJ45 port to DB9 port. Thank you
574
Morning everyone, I am having trouble finding information on the following subject and was hoping someone could help. I have an application that...
2,400
Attached is what I got on a Horner HMI. I'm trying to just establish basic modbus comms. Could someone tell me what pin out I should use on a...
3,147
Hi guys! I'm trying to build a cable to connect twido plc (RS485) and altivar71 (RJ45). Anyone knows pin-out for this connection? Does it matter...
12,884
Hello All I have a modbus tcp device(Julabo magio) with an DB9 pin assignment. Pin3=B and Pin8=A. I would like to connect it on the secondary...
1,621
