Pinout Modbus TCP onto S7-1200 through profinet port
BVG
Apr 2012
Ghent
Hello All
I have a modbus tcp device(Julabo magio) with an DB9 pin assignment. Pin3=B and Pin8=A. I would like to connect it on the secondary port of a siemens PLC S71200 (X1:p2). Now I was wondering which pin of the S71200 (RJ45 connector) i need to connect on the DB9 connector. My theory(after some google pictures):
A = +TX and +RX
B =-TX and -RX
S7-1200 port is full duplex;
Pin1:+TX
Pin4: -TX
Pin5: -RX
Pin6: +RX
So:
DB9.P8(A)= 1+6
DB9.P3(B)= 4+5
What do you think? :unsure: i searched the siemens website but could find any pin layouts.
STOP before you try to wire them up more! Might break something.
Modbus TCP uses Ethernet, it's pretty much in the name. I've never seen Ethernet over DB9, although always a first time for everything.
If your device has a DB9 port, I strongly suspect it's good old serial modbus RTU. Can you post a link to the device?
No worries, wiring is for next week :)
But you are correct. I rechecked manual of the device. They just specify DB9 connector as a RS232/RS485 interface so it's indeed a good old modbus RTU. They also have an RJ45 ethernet interface for the modbus TCP/IP registers i guess. Was stuck into a manual rabbit hole. Ty for helping me out!
Gents - hope somebody can help out, I've been tasked with fixing an OLD SCADA system. I've got an S7-226 PLC thats configured for Modbus comms via...
1,452
I have a project which i will need to use both comm ports as modbus rtu master. I purchased a 1763-nc01 for the mini din connector(channel 0) but...
4,748
I have a project that the pinout for various components is starting to make me doubt myself. I am hoping someone on here can confirm or correct...
5,261
Can someone direct me to the correct pinout diagram for a RJ485 modbus cable.
17,061
Hello guys, I am trying to control a ATV12 via Modbus Poll software. I need the connection diagram for Altivar Modbus RJ45 port to DB9 port. Thank you
571
