RJ45 to DB9 Pinout Help
Bateman87
Jun 2013
New Hampshire
Morning everyone,
I am having trouble finding information on the following subject and was hoping someone could help.
I have an application that will be using a Xenox 1900 barcode reader that has a RJ-45 connector plug. I want to get the barcode reader talking through a 9 pin Dsub connector with a MicroLogix 1400 processor.
I have not been able to find a wiring diagram on the correct pinouts for each connector. ( RJ-45 and 9 Pin Dsub)
I tried calling Honeywell and Xenox for help, but they have don't have any diagrams.
If anyone could lend a hand, that would be great.
Thank you
I do not believe that there is a standard for serial (rs232or 485) RJ45 pinout. Each manufacturer can have whatever pinout they choose. Contacting Xenox would be the best course.
Xenon seems to be just the brand. I can not find any information on them on google. Honeywell has no idea as to what the pinout would be either. I have called them twice now and they are no help.
I did find THIS which gives the pinouts. Note that it's a 10-pin RJ41, although an RJ-45 will likely work. Just remember to offset the pin numbers by one. Based on that drawing, pins 4 and 5 at the scanner would go to pins 2 and 3 at the PLC (might need to be swapped), and pin 3 goes to pin 5.
-Eric
Hello guys, I am trying to control a ATV12 via Modbus Poll software. I need the connection diagram for Altivar Modbus RJ45 port to DB9 port. Thank you
574
Attached is what I got on a Horner HMI. I'm trying to just establish basic modbus comms. Could someone tell me what pin out I should use on a...
3,147
I'm connecting up two remote ethernet devices to the switch in my control panel, and I'm trying to do the cleanest install. The customer typically...
590
Hi, I have a SLC5/03 connected to a working HMI via RE232 port, and connected to a broken HMI via DH485 (RJ45), I want to use the cable that used...
3,306
What is a good method to daisy-chain a number of RS485 4-wire devices that only have RJ45 ports. Is there a special device or adapter or do you...
1,831
