RJ45 with RS485
bluenoser337
Apr 2003
Nova Scotia
391
What is a good method to daisy-chain a number of RS485 4-wire devices that only have RJ45 ports. Is there a special device or adapter or do you have to jam jumpers inside the CAT5 connectors?
Hello guys, I am trying to control a ATV12 via Modbus Poll software. I need the connection diagram for Altivar Modbus RJ45 port to DB9 port. Thank you
575
What do you guys use for connecting several Modbus RS485 devices with a single RJ45 port in the one panel? and terminating resistors?
3,058
Hi guys! I'm trying to build a cable to connect twido plc (RS485) and altivar71 (RJ45). Anyone knows pin-out for this connection? Does it matter...
12,888
I'm connecting up two remote ethernet devices to the switch in my control panel, and I'm trying to do the cleanest install. The customer typically...
592
Hi, I have a SLC5/03 connected to a working HMI via RE232 port, and connected to a broken HMI via DH485 (RJ45), I want to use the cable that used...
3,316
