Pinout for servo 2090-FXNFMP-S15
phuz
Jun 2008
Mohnton, PA
1,044
I am trying to find a pinout for the cable mentioned above. Unfortunately, the manuals only reference 2090-XXNFMP-Sxx and I need "UX".
We are swapping Ultra3000 servos for Kinetix 5500 and the new cables that AB gave us do not plug into the motor MPL-B640F-S, which is the part number provided to the distributor.
It worked on the new motor, but not the older one, so we could not use the new encoder cable, and have cut the existing pre-molded cable and are trying to find the correct pinouts.
I want to rule out the cable as an issue so I need an HD15 connector. Unfortunately a VGA cable has unused connections and won't work (as I just verified).
Is anyone aware of a 15 pin connector that would have all pins wired that you could get at a local store?
Hello guys, I am trying to control a ATV12 via Modbus Poll software. I need the connection diagram for Altivar Modbus RJ45 port to DB9 port. Thank you
575
Hello All I have a modbus tcp device(Julabo magio) with an DB9 pin assignment. Pin3=B and Pin8=A. I would like to connect it on the secondary...
1,625
im tring to find out if i have a bad power supply for my panelview 1000 plus. does anyone have the pinout for the 10 pin connector on the...
1,864
Anyone happen to know the pinout on the RJ12 side of a GE HHM cable? It's just a serial 3-wire and I know the DB-9 side. Thanks.
1,076
I need to emergency fabricate a cable to program a Parker 690+ VFD. Part # CM351909 I believe. RJ6 on one end, DB9 on the other. I cannot find the...
2,302
