Pinout of cable connect PLC IDEC Microsmart pentra
Hi why not use ethernet or usb as thesae ports are availablr. In my experience home made leads are not generally very good
Cable Connector Pinouts
Pin Description
1 DCD Data Carrier Detect
2 RXD Receive Data
3 TXD Transmit Data
4 DTR Data Terminal Ready
5 GND Signal Ground
6 DSR Data Set Ready
7 — —
8 CTS Clear to Send
9 — —
I found this Idec pinout for the 8-pin mini-din connector. Use the post by TWControls for the computer end DB-9 female connector.
CAUTION: This may or may not work, I did not find the model number of the Idec PLC. Use at your own risk.
Pin Description
1 RTS Request to Send
2 DTR Data Terminal Ready
3 TXD Transmit Data
4 RXD Receive Data
5 DSR Data Set Ready
6 SG Signal Ground
7 SG Signal Ground
8 NC No Connection
Cover — Shield — —
Tried a straight through 9-pin RS-232 and a null model cable. No luck so far.
1,552
Anyone happen to know the pinout on the RJ12 side of a GE HHM cable? It's just a serial 3-wire and I know the DB-9 side. Thanks.
1,073
I need to emergency fabricate a cable to program a Parker 690+ VFD. Part # CM351909 I believe. RJ6 on one end, DB9 on the other. I cannot find the...
2,300
Gents - hope somebody can help out, I've been tasked with fixing an OLD SCADA system. I've got an S7-226 PLC thats configured for Modbus comms via...
1,455
Hi, I know this is not a PLC issue, sorry. I have a Sick Safety Laser Scanner and I wanna get connected to check some issues on it. I do not...
2,716
