Pipe Animation in WinCC 7.0
Jul 2007
Kiruna
600
Hi Guys,
I need to animate the pipework on a few process mimics in a WinCC application. Not something I am a fan of due to the work involved but thats how it is.
I am porting an application from FTView and struggling to find a solution on how to do it.
C-Script on the background of object? e.g.
if (V1.CLosed && V2.CLosed) Set Background colour?
Is this the best approach?
How about a GLobal action on a cyclic timer? Its going to be a huge script and worried it might affect the proformance
I think you solved your problem,I just wanted to write my experience with c-scripts.
c-scripts are making wincc to run like an old turtle. I had one wincc project where 10 small c-scripts were running at one pdl, pc was freezing alot ( minimum 2 times everyday), i converted c scripts to dynamic dialog,i made some calculations inside of plc,insted of making it at wincc. after that, I forgot the place of pc. also vb scripts are better for wincc. when i hear word of "c script" i have some pain in my stomach :D
Gentlemen, I have an idea that the reliable or at least repeatable results for “pipe animation” could be achieved by creating an piping routes...
2,734
Hi, gents! I'm just wondering if anyone works in process control industries and faces the same challenge. Customers want to have the pipe system...
49
14,926
Hello, I've searched long and hard for this and found a great thread from 2008 about animating pipes and it turned out it was a bit of a flame...
26
709
Hi all, Related to my other post, I also need to measure some quite low temperatures (down to -50°C) in pipes. For the most part this is fine -...
1,578
Good morning, Curious what the function is of this piece of steel pipe that a motor wire run through. The same thing is installed in the encoder...
2,706
