Plc 5/80e connected to 1746 ni8 card issue
James Mcquade
Oct 2007
Nashville, Tennessee area
3,684
Hi all,
i have a plc 5/80e connected to a host of racks.
one of those racks is a slc 500 series
it is Rack 015 Group 6
the Ni8 card is Module 0
my problem is that we have several monitors connected to the input card and the zero point has drifted.
we are using a btw to the card with a configuration word of 3852.
the btr places the data in the next sequence of registers.
the program is setup for 4-20 ma.
the program math is set up for a result of 0.0 to 25 in the f8 file.
is it possible to get the math to read -1 to 25 and how would i do that in the configuration.
i'm not well versed in this area so any help would be much appreciated.
thanks in advance,
james
Its possible but not in the configuration , in the math that scales the data to engineering units.
The configuration word value you posted would indicate the card is configured for 0-20ma with a scaled for PID data format.
That would give you 3277 counts at 4ma and 16383 counts at 20ma.
To scale that to -1 to 25 use compute instruction
((Raw Data-3277)*.00198))-1=Scaled Data -1 to 25
Post your program and point us to the math that scales the data now.
I may have misread your problem after reading it again, is this zero point the analog cards raw value at 4ma?
If so you may have to apply a known 4 ma and take note of the raw value counts, also do the same at 20 ma. Then use these new values to compute your engineering units 0-25.
If you can provide these values someone can help with the math.
mickey,
thanks for the heads up.
we have several 4-20 ma monitors in the plant.
each is calibrated for 0 to 25.
what we have discovered is that on two of the units, the zero point has drifted into the negative area rather than staying at zero.
what i am trying to do is to see if anyone has been able to change the calibration / setup so the plc will be able to compute a -2 to a max of 23 or 25.
the problem is that this is the zero point of the meter.
if this was a slc 500 i wouldn't have a problem, i would use the scp command and a calibration meter to get my unit programmed.
regards,
james
Please help me! I need to perform the firmware update for PLC 5 1785-L20E / 1785-L40E and 1785-L80E, but I do not find these firmware to download...
2,417
This will be one of those "I'm not a PLC guy, but I'm helping them troubleshoot" questions. I'm on the computers / network side. We have a...
4,988
Hi, I am not used to work woth PLC5 so I'll give a brief explanation of my problem: I have a PLC 5 80e that work as a I/O scanner (port 1B)...
2,659
Use rack 14 as an example. It is split into 2 1/2 racks, groups 0 and 4. S:32/4 gives me the fault for the entire rack 14. How would I identify...
3,153
I know some operators are turning off equipment while it is idle to falsely reflect higher production averages. The equipment has an hour meter...
1,840
