PLC 5/80E count off time
todster
Apr 2007
NY
175
I know some operators are turning off equipment while it is idle to falsely reflect higher production averages. The equipment has an hour meter that is controlled by an output from the PLC and reflects on time. The on time is then used to calculate their productivity. Turning off the machine everytime they are idle for a couple of minutes increases their averages. When it's off and they are on the clock, it counts against maintenance as downtime. I would like to record the time they stoppped and the duration. All the values will be stored in files on the PLC and most likely only viewed with a CDM. I can use the RTC and EQ/NEQ to filter out the off shift times and days. It would be nice to also use the RTC to label the files by work shift. I have a few ideas on doing this. I will be sitting in a hotel for the next 2 weeks. I figured I could go a step further and get some great ideas that will turn this into a learning opportunity as well as something that I might implement. There's more than 1 way to skin a cat.
I'll be doing this on RS500 with an emulated 5/04. Not sure if the emulator will give me the RTC but I'll fudge what's needed.
Please help me! I need to perform the firmware update for PLC 5 1785-L20E / 1785-L40E and 1785-L80E, but I do not find these firmware to download...
2,417
This will be one of those "I'm not a PLC guy, but I'm helping them troubleshoot" questions. I'm on the computers / network side. We have a...
4,988
Hi all, i have a plc 5/80e connected to a host of racks. one of those racks is a slc 500 series it is Rack 015 Group 6 the Ni8 card is Module 0...
3,213
Hi, I am not used to work woth PLC5 so I'll give a brief explanation of my problem: I have a PLC 5 80e that work as a I/O scanner (port 1B)...
2,659
Use rack 14 as an example. It is split into 2 1/2 racks, groups 0 and 4. S:32/4 gives me the fault for the entire rack 14. How would I identify...
3,153
