PLC 5 BTW/BTR Problems
wa5yom
Sep 2003
Ardmore, Oklahoma
138
I have an application that is duplicated on a similar production line.
A 1794-IE8 Flex I/O module is installed and connected to 4 pressure transducers.
The BTW and BTR is configured and programmed the same as the similar application...however, I am getting an error on the BTR/BTW.
My only explanation is that there is a hardware issue.
Any suggestions?
The Length element of the Block Transfer control block provides an error code if the value is negative. What is this error code ?
Do both the BTR and BTW instructions get errors ? Are there any other FLEX modules on the same adapter that work correctly ?
Is this a new installation, or did it stop working after working correctly for some time ?
Have you tried a new module, or tried swapping modules with the other production line ?
I set up an analog card (1771-IFE/A) in differential mode, this gave me 8 functional analog inputs. I used the RSLogix generated rungs with a BTW...
3,755
Hello, I'm new here and looking for some help from you all. I'm writing BTR and BTW instructions in RSLogix 500 for a 1794-IE8 card with...
7,267
The present system:- Consists of a PLC-5/40 E CPU mounted in a 8-slot chassis. There are several remote I/O panels consisting of five 16 slot...
43
30,124
Good Evening , I need to convert a PLC 2/17 ( RS Logix 5 ) over to a CompactLogix 1769-L33ER . I took notice in the RS Logix 5 program that...
2,089
we have the sytem in which a lot of PLC 5/80E, 5/40E,SLC 5/05 etc are connected thru ethernet to HP-alpha server. Now the server has been updated...
4,841
