PLC 5 Program Reset
Is the analog output a 1771-OFE, or another device that takes a bit pattern and converts to analog going out to the valve? Writing to an output word implies the latter, possibly something on remote I/O or discrete-to-analog.
I'm guessing it's not an 1771-OFE module, given that the max scaled range for BCD or Binary is ±9999
Looking at the values being moved in - 20,000, 16,000, 24,000.
@MarkNightingale, what is your analogue module?
173
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
118
Posted this to Reddit with little success, so I figured I would share it here as well. Very new to PLCs, but figured I would give it a shot to...
151
I'm a beginner in the automation field and I've set up an automation system connecting several devices (datalogger, radio, etc.) via Modbus RS485...
243
Hi All, want to ask. I have PLC a programme to control the valve. The existing programme is to control valve A (Y22), and I want to change to...
172
