PLC 5 redundancy issue
kphilman
Nov 2006
Chattanoooga,TN
I have a plc 5 system with 5/80e processors and have bcm redundancy modules, I have a wonderware system using ethernet to talk to the processors and would like to know what will happen when the primary becomes the secondary and wonderware polls the primary. I am under the understanding that plc5 redundant systems do not swap IP addresses, how can I make the plc's swap IP addresses.
We had a similar proble a few years ago, except we were using Citect instead of Wonderware. Rather than change the PLC's ip address we ended up getting Citect to swap PLC that it was talking to.
What we did was to set a bit in the PLC that would only be ON if that PLC was the one controlling the process. The n we wrote code in Citect that would disable that IOdevice and enable the other one if it ever found that it was "talking" to the standbv PLC.
Hi everyone, Recently we have upgraded (5564) L-64 to (5575) L-75 with redundancy PLC and after commissioning, New system is going to off line...
1,408
Hi, I had a client upgraded their system to use a set of redundant PLC system with GE PLC CPE400, and a Citect 8.0 (2016) SCADA to get data with...
1,451
Is there a way to know which is the primary and secondary chassis through gsv? I have read that "PhysicalChassis" (Chassis A/Chassis B) is an...
2,243
Hi, I have a problem with Media Redundancy. My config in test is like this: When I disconnect 1 side, the red lights goes on and the slave...
2,561
Good Morning , Yesterday we had some downtime due to some communication problems with remote Ethernet I/O. I am still a fan of hardwiring...
3,391
