plc AB 1769-l24er number of nodes
filiks
Apr 2023
USA
hello plc professionals ,
i have a plc AB 1769-l24er and 13 VFD AB 525 and HMI and STRAIX 2000 unmanaged switch ..
the LOGIX Designer limiting me up to 8 points ( NODES ) and im not able to add more VFD's to the program as a modules
is there anyway to bypass this issue ?
thanks in advance
thank you OG
thank you @OPERAGHOST , it looks like i've no other way to proceed in my project . do you know how much is it or what is the price difference between the 24 and 27 ?
it seemed like yesterday , when I bought a 1769-L24ER-QB1B for $3xx.
A L27ERM motion will cost you $4600.
You can definitely bypass it, it will cost you $2600 for 16 nodes. Is that enough?
that will be on the customer not on me , I was trying to bypass it through the firmware or using any kind of software but no hope
Multi Drive mode. One master can serve up to 5 followers. Some draw back with ADC and little slower communication throughput.
Been seeing a high failure rate on these PLC's on 2 of our process. The control power is feed through a APC UPS to a 24VDC power supply to power...
4,032
Hello, I want to understand what each terminal does on the Embedded High Speed Counter on the 1769-L24ER-QBFC1B PLC? I read the manual, but I...
2,969
Hello Guys, I am using 1769-L36ERMS PLC by Rockwell which doesn't let me MOV or COP literal text into string datatype? i very well know the...
396
Hi everyone, Kind of new at this, so we recently upgraded our 1769-l32e to the newer 5069-L320erm, i converted the file over and Verify the...
401
looking for the the MAC address for this PLC, I count find it in the front or at any part of the PLC itself. connected to the PLC by USB, showing...
1,762
