Plc addressing ?????
bigbri
Jan 2011
UK
Hi all,
Although I'm an electronics engineer, I'm new to PLC's ! and am in the middle of doing a course. One of the questions I came across while doing it was:
What is wrong with the following program?
| 0.00 1.02 1.01 0.02 1.02 0.07
|---|/|-------||-----|-------||-----|/|--|----|/|-----O--|
| 1.03 0.04 | 1.05 |
My answer to this was that there are two contacts that are addressed the same (1.02) on the same rung.
Apparently there is another fault, but i can't seem to find out what it is???
Anyone??
Thanks alot
Bri
Thanks Mickey,
My diagram didn't make accross the web in ASCII !!!
However, your link has answered my question.
Thanks all
bri
I have a system using Rx3I CRU320 redundant CPU with Proficy Machine Edition Software. In the hardware configuration of each CPU module, under...
412
Hi All Working with Tia v16 on a PLC 1515F I am getting older by the minute, beating on indirect addressing for a DB I have a DB with 65 row of...
3,794
Hello I read your info about modbus addressing with %MW register. I have a PLC with registers PLC ADDR: MW4513 and the machine constructor write...
7,165
Hello guys, This works: L P#DBX 30.0 LAR2 But I need "DBX 30.0" to be input parameter to the function. I made pTag variable with data type...
19
6,414
Greeting, I am doing some investigations on which driver(s) support tag based addressing (eg. Pump001_Running) rather than DB or Modbus based...
3,758
