PLC Analog Input Module
umrz180
Apr 2016
Islamabad
I am a student of BS Electrical. I just start a new project ' Protection and Fault detection of 3-phase induction motor using plc'. As PLCs are of different types. So selection of PLC is difficult for me because i am just the beginner in PLC studying.
For protection of induction motor different parameters will be input of PLC. As i studied untill now i need 3 sensors which are winding temp. sensor, ball bearing temp. sensor and speed sensor.
Apart from these 3 sensor, i need 3 CT's and 3 PT's for voltage and Current measurement.
Overall i shall have required 9 inputs which are analog. For analog inputs, analog cards are necessary. so i need an information which PLC is best to cover these analog inputs and how many analog cards will be used. I am so confused about this thing. IF any one of you have any better idea then suggest. I will be very thankfull.
Hi all, I’m an electrician with limited knowledge of PLC circuits. Typically I will see simple 2/3/4 wire terminations for transmitters on...
26
1,284
Hi all, I want to catch min piks of an analog signal when digital signal is on(pls see the attached oscillogram). My hardware is 5069-L306ER CPU...
1,010
Hello I have a analog input signal that is bouncing a bit. The PLC card is a 1769-IF8 I changed the input card filter setting from 60hz to 50hz...
4,903
Dear all I am using delta AH530 RS- 2 cpu with devicenet communication and now I am getting problem while configuration of AH6xa-05 which is...
1,049
Hello everyone I got problem during practical. I am using delta plc model:DVP20EX00R2. Problem is that when i give 7v dc supply through bridge...
2,457
