Plc And Gsm
The Engineer
Guest
T
i have plc which is S7300 and GSM (mc35i) from siemens... my gsm will be connected to the plc so the plc will send a messge to the gsm modem and the gsm modem will send it to another gsm modem which is connected to a pc. so i want to use ladder programming for that plc to send and recieve messeges from the gsm (mc35i). can you help me becuase on the net i didn't find any material. i wish i can have help please!
I have done this with mitsubishi plcs in ladder. If the program would be any help ill send it on any help ill send it on.
i've done that project, but i work on omron plc. I used microcontroller as bridge to communicate GSM and PLC. ATcommand from handphone is translated by microcontroller via serial and plc read from plc via parallel.
Dear Sir
Pl let me know , how to use / connect Wavecom GSM to Mitsubishi PLC Fx using Rs232 BD card ?
Mangal
Hello Engineer;
Siemens suggests using their Teleservice adapter and Teleservice software to establish the link with GSM modems and their S7 PLCs. You can have a description and further links on the following Siemens webpage:
http://support.automation.siemens.com/-snm-0135109872-1110474974-0000002412-0000000518-1110628582-enm-WW/llisapi.dll?query=gsm+modem&func=cslib.cssearch&content=skm%2Fmain.asp&lang=en&siteid=cseus&objaction=cssearch&searchinprim=0&nodeid0=4000024
Hope this helps,
Daniel Chartier
Mangal,
You can use AT commands to communicate between the modem and the Plc. You Can use these commands in hyper terminal. (this is to set up and test your modem). Then you must use a program in the plc to send the Commands automatically.
If you tell me were exactly your at (or were your having problems) ill help you.
For setting up the modem in hyper terminal using AT commands. the following will help.
http://www.btinternet.com/~paul416/PLC/Modem.pdf
Can You give me the example mr. Quinn ? so send me to : [email protected]. Saya gunakan PLC Scadapack sama Quantum. Udah pernah nyoba belom ? Trims
I recently purchased a GSM modem model number SGM510 from a local dealer in Mumbai, India and I am trying to connect it to a Delta PLC that I have...
1,707
Hello Experts.... Could anyone guide me that in one application I have to send SMS data using GSM module & Micrologix PLC. By reading some...
1,565
I have a task where I need to send SMS with system problems alert through PLC. I think PLC is not matter. Let's say it have RS2323 and 485 on...
2,109
Hello I am new here and came for some help. I working on project where i need to send a bit to 5 other plcs at the same time but this must be...
4,191
Hi Guys I'm a technical person who has been tasked with the job of sending sms from Omron PLC CP1E-N30DT-D to GSM Modem for alarm purposes. Now...
1,375
