godfrey
Is there a way to check the energy left in a PLC CPU battery? I know of a few systems which set a status bit when it's time to change it. Do they just look at voltage? What I'm getting at is, prior to the status bit being set, is there a way to test how far the battery is from this point? Using the AB SLC as an example, the battery has a nameplate rating of x. Is there a published or known value below which the status bit will be set?
I'm looking at this from the standpoint of scheduled maintenance.
