PLC battery
johneedw
Oct 2009
asia
204
Hello friends,
The battery of my omron plc goes low and need to replace with a new one. The original battery value is 3v exactly, while I've a new one of a value 3.6v!..
Please advice me if it is possible to use the new battery to feed this plc?..
Help me Plz!..
New lithium batteries are 3.6V
Calling them a 3V battery is a shortcut to distinguish them from 1.5V batteries.
Much the same as the 12V battery in a car is usually around 14V
They recomend that you replace with the correct battery, however, I have replaced many batteries in many types of PLC's with ones from RS or other suppliers & never had a problem, just make sure it is of the same type i.e. lithium or what ever, also, most PLC manufacturers suggest switching off the power but replace within a givewn time i.e. probably less than a minute or two, however, again I have replaced hundreds of batteries while power on & never had a problem, but most will require a re-boot to remove the Batt error light.
We had a yearly plannede maintenance to replace all batteries in PLC's rather than leave them for say 5 years, some PLC's can drain the battery if powered off for long periods & the battery has been in place for sometime.
..co worker who was supposed to be an expert knew enough to get hired. lucky for the plant, i had a current copy.
james
Sounds like the expert electrician that was hired for me without me interviewing him. His brother was the supervisor of the weld department at the automotive supplier I was at in the 90's.
Turns out his entire experience was working on buildings (couldn't touch any equipment) for KFC and the ONLY 2 things he ever did was replace light fixtures and thermostats - now he's the only electrician for a stamping plant with 55 presses, never saw a schematic in his life and didn't know what a relay was.
Hi there! This is something so old and having machine with it....... Last time unit was powered around 3yr ago and it did not work since than...
241
Hello, I am doing research project focused on the retrofit of a diesel locomotive into a hydrogen-fuel-cell-battery hybrid locomotive. The...
531
At the moment on my application (S7-1212C), the PLC/HMI are showing the correct time, i.e. the displayed time matches the time of the clock on the...
919
Hello Everyone, I have a Mitsubishi PLC FX3U According to Mitsubishi PLC manual we have to power off the plc and change the battery in 20...
1,711
Hi all, I have a Kuhnke 680 PLC that has an onboard battery that is totally dead, so loses all settings when it is shutdown. The batteries have...
511
