plc control of stepper motors
Dinesh_Vather
Mar 2003
Dublin
This is my first time in this site I hope you can help me. I am doing a project that involves the control of stepper motors with a plc i have not picked a plc of stepper motor yet so if anyone has any help... thanx banghead
Dinesh,
There is a vast range of PLC and Stepper. You have to choose one according how familiar - at least on one of the item - and decide the other on based on your application and availability in your region.
Normally steppers comes in at least 2 variants, stand alone units which interface with PLC digitally. The other one, the pulse generator and controller resides on the PLC and drives the stepper through a external driver.
In this region Vexta stepper from Oriental is quite commonly used for stand alone units. In AB PLC there is a stepper control module that resides on the rack - the HSTP1 module which is controlled directly through your program codes. So does Omron PLCs
Consider your needs, availability and decide appropriately
beerchug
Dear,
u know that stepper motor system has the following parts, which depend each other so.
1-to select a motor. u have to specify the following.
a-number of pulse/rev.
b-motor power.
2-select the power supply according to motor power.
3-select the drive controller.
4-then u can use any plc has a pulse train output. This pulse output frequency must be grater than the frequency pulses u need to achieve your speed.
rotation speed(rev/sec)= (output pulse per second)/(pulse/rev)
Hello all, I am completely new to PLC programming and automation in general. I am working for a company that wants to use a TECO SG2 PLC to...
1,522
I am would like to use a FUJI electric SPB PLC to control a stepper motor. I need the stepper motor to drive a rotating plate a specific number of...
4,619
Hello, First off I'm not an experienced PLC programmer But I have been using a single axis stepper controlled via a PC for 6 years or so...
17
8,425
Hello, as I know, usually special modules are used to control stepper. So i'm wondering why not just connect stepper to the PLC's digital...
4,215
I started off yesterday not knowing a thing about stepper motors, so hopefully this makes some sense and i am not missing something simple and/or...
18
10,624
