Precise Stepper Motor Control with PLC
Blake88
Nov 2016
AKL
I am would like to use a FUJI electric SPB PLC to control a stepper motor. I need the stepper motor to drive a rotating plate a specific number of degrees or steps each time. Is a PLC sophisticated to send the correct number of pulses to the motor and stop or can it only turn it on until a timer or switch stops it?
Alternatively, are there any rotational pneumatic actuators that can give precise rotational movement? I am trying to avoid linear pneumatic cylinders with a rack and pinion.
Check if the unit can output PWM signals. You would be sending these to a stepper motor controller, not direct to the motor.
How many different step settings do you need? If it is the same each time, i.e. go from 0 degrees to say 28 degrees, you can get rotary pneumatic with hard stops (from the likes of SMC, Shunck, etc).
Another option is the likes of: http://www.smcworld.com/products/en/electric/s.do?ca_id=626
Whereby your PLC would send digital IO to its controller, e.g output 1 on, goes to 10 degrees, output 2 on, goes to 15. This is setup in the SMC software, most units have 64 configurable step settings.
...and welcome to the forum...
I have done a few rotary table with different assembly stations with stepper controls. We ended up using a locking guide after the number of pulses to ensure the table was in the correct position.
Thanks!
It does only need to rotate the same amount each time.
A rotary pneumatic with hard stops looks like it could be a good option for me.
The PLC I have can output PWM signals, if I go down the stepper motor route, is the stepper motor controller a separate PLC style device or is it something more sophisticated like arduino? This is for a pretty basic industrial environment and I don't want to overkill it with more tech than it needs.
Thanks Gary, locks are a good idea, the current pneumatic system has a lock system that I will adapt to work with whatever upgrade I install.
Is it turn once and back to 0 or are there more stations? The schunk I listed are generally the former.
For the latter the SMC units would be my choice over plc/stepper... the arduino can use add on cards (shields) which essentially are a small stepper controller.
hi all,, how precise movement of servo motor can be control through PLC(delta), any suggestion ?? and which is more Suitable...using servo motor...
5,487
Hello everyone. I'm currently trying to make an automated test bench for my company. What it needs to do is burnish friction material, and as part...
33
8,568
Hi Everyone, Before I go to efforts to create such a system, I would like to know if anyone has come across such a system. The requirements are...
2,525
HI everyone! I am trying to use a Micro850 to control a SureStep (Leadshine) Stepper drive (DM805-AI) from Automationdirect. I have no trouble...
181
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,033
