PLC Contrologix battery
Yes it is - gives you a longer memory retention with the power off.....
A-B have a history of not using rechargeable batteries, probably wanting customers to buy their backup batteries... all that has changed with the L7x series of processors... see below.
A short summary.....
L1 and L55 processors use battery power to retain the memory while the power is off. The longer the power is off, the more battery power is used, so don't keep the processor powered-off for long periods.
L6x series processors use battery power to transfer the volatile memory to flash memory each time the power is lost. The more frequently the power goes off, the more battery power is used, so don't keep switching it off repeatedly.
L7x series processors use an "Energy Storage Module" which is charged while under power, and is used to transfer the volatile memory to flash memory each time power is lost.
I have a customer who wants to control his DCS800 drives via Ethernet, so I have bought two RETA-01 cards. At the moment they are connected via...
1,004
Hello all. I have a system that has single phase PF40 that I would like to replace with a 3 phase. Since I do not have the ability to change the...
2,246
Good Morning , I should know this . I would like to import some rungs into a running ControlLogix PLC . Can you actually keep a...
1,631
Does anyone have any experience connecting a Cleco Nutrunner via EtheNet/IP to a ControLogix PLC? I have an mPro 400gc-p and a 1756-L73 PLC with...
1,523
Hi everyone, is there anyway to read more than just one generic ethernet module with the same IP address in RSLOGIX5000? i just can read one...
1,237
