PLC & HMI time
Tom@Pton
Dec 2009
Central Nebraska
159
Down to the last details and have added a RTC to the AB 1500 I am using. I would like to sync the time of the PLC with that of the C-more HMI. The HMI time is easy to set for the customer but not so for the 1500. The 1500s RTC is read only as I understand it so I believe the HMI will need to read the time of the PLC. What is the data type for the RTC?
Thank you.
Tom,
I don't have an RTC in my 1500 here at home but if you hold your mouse over the address in the function file it will tell you.
Example HR-Hour = RTC:0.Hour, Integer and DAY-Day = RTC:0.Day, Integer.
You can also open the RTC function file and drag these address into your program and check that way also.
Hope this helps.
68
Hi, Wy we log data in PLC using DLG instruction, when we have option to log data in HMI
97
Hi, I'm thinking about using commands for Melservo J5 controller via HMI without PLC. Have you guys done this kind of control configuration for...
155
Hello, I have an automation direct d2 262 plc and C-more HMI EA9T6CL-R. I need to prepare a program, scheduled to be performed on a future date. I...
142
Hi Iam using monitouch hmi(V9 soft) with omron plc cj2m (CX programmer). In this I want to read a data from hmi to plc. The data was like...
109
