plc in substations/elec utility
zorina
Jan 2003
hi. i just want to know if any of you has a success story regarding the use of plcs in electric utilities and/or substations. thanks.
Absolutely!!! Have used Omron networked PLCs in fully automatic base load diesel generator power stations several times. Christmas Island, RAAF Base Scherger, Weipa etc.
zzzzz
CLECO (Central Louisiana Electric Company) has a couple of installations using C200H at Alexandria and Ruston as circuit breaker reclosers.
Electric utilities
Yes, my last job was using Allen-Bradley 5/20e, 5/40e PLCs and 1400e PanelViews. Ethernet communications over a three ring fiber optic network.
S.C.A.D.A. of three main substations and switchyards, 138kv with 50 branch substations all monitored and controlled from a switchboard control center. The system also contained 250vdc generation and distribution as well as 6600vac 25HZ generation and distribution.
Note: Allen-Bradley120vac Triac input cards will work on 25-cycle power.
hi folks, any authority on the use of plcs in substations? would like to ask a few questions please let me know tanx
2,342
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
46
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
73
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
47
Hi everyone. I'm trying to read values from a Loadcell with a 2080-TC card. I know the 2080-TC is a thermocouple card but it reads millivolts that...
84
