PLC IP for high Voltage and curret
TKE
May 2011
Belleek co fermanagh
Hello everyone this is all new to me i am trying to design a program to run a 20kw wind turbine but need to know how can i measure high voltage and current of 300VDC to 700VDC and up to 100Amps, has anyone experience with wind turbine application?
TKE
Thanks for the info, can anyone tel me how to check if my wind speed meter
and wind vane are digital or analogue as i have no makers name or info
thanks
TKE
obviously everyone is giving you a hard time.
I believe it is either DIGALOGUE or ANITAL
and wind vane are digital or analogue as i have no makers name or info thanks TKE
Uhhh do you have the manual??
OR you could hook to a scope and look at output when you spin it.
Uhhh Crystal Ball man - you got any spare batteries for your crystal ball I can borrow?
Dan Bentler
Sorry for the hard time mate.
More than likely it is digital - about 90% certain
Analogue - requires a known maximum value
- How fast can the wind blow???
Digital will give you pulses - so many per second
-this will give you reliable accurate speed
post a picture
howmany wires would you need to have a digital signal
Could you need directional signal
does it need a voltage
is it NPN or PNP
I still dont think it is analogue
Obviously, it makes most sense to place PLCs into cabinets with little to no high voltage AC (230V & 460V) signals present to help reduce possible...
4,561
Hi team! I'm starting some iFIX application migrations and some of them are being developed with the high performance library. Some objects that...
824
Hi, i need to make: 1- A PLC Program on Omron PLC CP2E-N using high speed counter E6C3-AG5B 360P/R 2M(Absolute) ,to Reject bottles on Conveyor...
891
Been seeing a high failure rate on these PLC's on 2 of our process. The control power is feed through a APC UPS to a 24VDC power supply to power...
4,050
Hi there! I'm using mitsubishi plc for some project controling. I try to use high speed counter C242 to reading an speed machine. I use two...
1,402
