use high spedd counter PLC FX1S
ngoclan
Sep 2013
vung tau
153
Hi there!
I'm using mitsubishi plc for some project controling. I try to use high speed counter C242 to reading an speed machine. I use two function move(DMOV) and HSCS(interupt set bit) relate to value of C242 but It can't work even the counter always was got value 0, and can't reset high speed counter C242
What happen with my FX1S plc:
Do i have to use interrupt subroutine, or immediate read high speed input, for Unitronics Samba plc or reading only the correponding register in...
124
Can anyone recommend a flexible 600-volt shielded ethernet patch cable? I have used them from Allen Bradley / Panduit before and they are too...
111
Hello Folks, Has anyone configured a Momentum high speed counter on Unity 13.1. We need the wiring diagram for Momentum High speed counter and...
82
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
258
Does anyone have any experience with working on piezoelectric motor control? I want to use off the shelf components to hopefully change the...
745
