PLC Keyence Link to PC
RoenZ
May 2008
Jkt
Hi all....
I want to ask about PLC Keyence about serial communication to PC.
How we can transfer data memory to PC (Visual Basic / Delphi) or vice versa ???
e.g:
If I have two sensor input from PLC ( proximity and temperature sensor) and I want to display the value from PC what step i must do ??
I've tried to send the data to PC but the PC only receive the data format like this #2....how we can convert it ???
As i know the Omron have a component to do this but i don't if the Keyence have component like this too ???
And if i send data from PC to PLC (e.g change the data memory) what procedure i must do ???
And the last thing....
What type of data for the serial communication ??? Hex,Char, or ASCII ??
Thx in advanced,
Best Regards,
RoenZ
RoenZ said:
Hi all....
In short, Yes, it can be done. I have done this but it was a long time ago. Have you looked at the Serial Communications section of the manual?
RoenZ said:
e.g:
Have you written this value to a memory location? If so, what location and memory type?
What exactly did you send the PLC? What did your command string look like? How did you send it? (VB, Hyperterminal, etc...)
If you are referring to the written protocol then yes, it is outlined in the manual under the Serial Communications section. It is very similar to Omron.
If you are referring to a SCADA program then... I don't know. I've never seen one.
Please see the above picture and read the following pages in the manual. This question is too broad.
You will send and receive 'String' data. You will need to strip off the leading and trailing characters to isolate the data you are interested in then interpret it as per the manual.
In the case of DM memory, the 'Text' in your string will represent a Decimal number.
This is what I remember. Good luck.
Hi all, Long time listener, first time caller:cool: Does anyone know if it is possible to interface any of the Keyence CV-2100, CV-3000 or...
8,186
Hey guys, has anyone worked with any type of Keyence PLC and could share their experience with it? Vendor showed me camera footage reply of a work...
1,182
I have a project I am designing a quote for an upgrade on. Per the schematic, the PLC I saw and an upload I took, it is run by an AB MicroLogic...
2,681
I have been hung out to dry by Keyence. If I had to do it all over again, I would NOT choose Keyence. They have done nothing but lead me in the...
956
Disclaimer, I do not know much about PLC’s, and am completely stuck on how to proceed, so any help is appreciated! I have an Allen Bradley...
7,352
