PLC Micrologix 1200 and VB6
glideratio
Feb 2009
US
62
Hi guys,
my task is to send/receive data from/to Micologix 1200 using VB6 (Visual Basic 6).
What version of RSLinx do I need for this application ?
Thank you
Regards
Mike
Is it possible to use DF1 protocol to communicate between Micrologix 1200 and VB6 ?
Or it doesn't matter at all for an RSLinx OPC server which communication protocol to use DF1,IP,etc
I'm gonna use DF1 rs-232.
Regards
Mike
The question is whether to use rs-232 or ethernet for Micrologix 1200, PC with VB6, and 2 Mettler scales.
So far I have few options:
Please see 2 .jpeg files attached
Any comments welcome
Regards
Mike
Personally, I use ethernet whenever posibble. In your case both would work as long as the distances between the PLC scale controllers and PC is short. One other thing to note is you will have to have specialized Serial port cards in the PC. IF you ever want to upgrade the PC you will have to change those cards with it.
On the ethernet side I would have everything go into a switch.
I just did some research and found that IP based network is more reliable.
Does anyone has any experience of communicating with Mettler scales over Ethernet using Visual Basic winsock?
How do you program a Micrologic 1200 RTD module using a Micrologic 1400 PLC? I'm using RSLogix Micro to program the ladder logic. I've wired the...
2,858
Which communication cable should I buy to communicate with a micrologix 1200 plc. I have Windows xp sp 2 running on a virtual machine on my laptop...
1,707
I am doing a PF correction and am using a micrologix 1200. I am trying to find the difference between 2 counts from my high speed counter. Is...
1,991
So I'm working on writing my first PLC program, and I don't really understand the PLC memory / data files. I see the various things like Integer...
4,017
hello guys. I m new to this blog and i dont know if there is already a thread discussed already about this plc. So i would like to start a thread...
2,435
