PLC not seeing another PLC
JoshM
Mar 2012
NYC
54
We have several compactlogix controllers and they have several global data points that they share.
One of the units lost control power and when it returned it came back seeing a majority of the PLC's except one.
I have seen similar situations and sometimes just running gpupdate /force command has fixed it in the past. Making me think it is some form of security issue, but its weird that it is always the same unit, not the PLC that lost communication power, and not any of the other PLC's.
Can I prevent this somehow?
Thank you,
Josh
No pronouns without antecedents !
You're going to have to explain how the controllers share data and what exactly you mean when you say that a controller "sees" another.
My first assumption when you say that controllers "share data" is that they use Produced/Consumed Tags, and a Windows permission would have nothing at all to do with that functionality of the controller.
if you are running ethernet, you should be able to pick them up in bootp, if you see them there, then make sure that they have an IP assigned if your running on IP adresses... Guess you need to tell us a littel bit more about your setup.
Hello everyone, this is my first post on this forum but it's helped me in the past and hopefully it will help me now. I'm trying to get a first...
1,225
I have a currently running PLC (Control Logix) with a computer connected running FTV ME Station for the HMI. Everything is connected via ethernet...
6,229
In FactoryTalkView, is there a function or tool that generates a list of all objects used in a project and their corresponding PLC tags? Thank you.
2,628
I have recently replaced an old Panelview with a new Panelview Plus 1000. It communicates with the old SLC PLC over a DH+ network. All the...
3,926
So I was called in Friday night a PLC was faulted. The fix was easy key reset. Have any of you guys made a message with FT SE to tell that there...
1,768
