PLC - OPC Problem
ivans
Guest
I
People I really need help. I am using a Mitsubushi FX2N PLC and a Sick Photo Electric sensor to count products being produced. The signal is then relayed to a Kepware OPC server. We are getting comms but the values do not change, they remain as 0
Are you using the Kepware server to try to read the accumulated count value or are you trying to read the photocell signal? The signal from the photocell may only be a brief pulse each time the product passes in front of it. If that's the case, the Kepware server will read it in the OFF state much more frequently than in the ON state.
First step when troubleshooting OPC is to use a test client to see if there is "hole through". Have you done this ?
Best is to use the one that come with the supplier (Kep), but any test client will actually do.
It will tell you if the problems are on the "server" side or the "client" side.
Hi all, I'm config opc ua in plc s7 1500 . I'm having problem security in opc ua . I'm using app c# in siemen support to test read/wire data to...
1,899
my name is danish i am using keyence KV24r plc, i want to pick it's data serially to HMI through OPC i have try KEPserverEX matricon and INGEAR...
2,830
Hi good day Everyone, I have a cimplicity v10 project with 7 to 8k tags communicating with AB PLC through OPC and Rslinx classic. I have this...
231
I hope this isn't an obvious question but can any AB PLC talk OPC such that it could read and write directly to Kepware (or IGS) system tags? OR...
2,717
Hi, I have a multiple PLCs (AB) running multiple applications, inc Motion, on different VLANS, but connected via Stratix5700 (CGN) switches and...
2,486
