PLC Time Sync with OPC Tags
About FTView ME and PanelView Plus terminal time:
One of the unusual features of PV+ is that it doesn't have an ordinary NTP client that's independent of a connection to a Windows domain. If you're not using domain authentication and membership, then you don't have an easy way to get the PV+ system time set via an upper-level network. (This might have changed with the new PV+7 Series B with Windows 10 IoT Edition).
But it does have a Global Connection that allows you to read specific tags for each element of the system time from a PLC, then use another boolean tag transition from false to true to have the PV+ apply those values to its system clock.
For most users, those tags are derived from the Status file (PLC/SLC) or using a Get System Variable (GSV) instruction to access the Wall Clock Time (Logix).
But they don't have to be. They could be tags written by your OPC server to the controller, that aren't connected to the controller's clock at all.
Thanks Ken, I have accessed all these resources. Indeed the aim is to use the Global Connections to manage the time in the ME stations from Tags in the machine PLC. These tags were to be derived from a syncronised PLC master clock, but the issue with disruption to the Motion control when time is managed this way prevents me from using the PTP or CIP automatic time syncing. Which I why I want to self manage the Time values in the PLC tags that are connected to the ME stations, and other devices (Printers, HMI, scanners and vision systems).
Many of these systems create time stamps on internal file systems and logs, so we need a unified Time zone across the manufacturing site.
I think for me I have established my route forward. OPC deriverd Tags.
Hi, I'm working with a Citect OPC DA server and an Allen Bradley ControlLogix L71 PLC. I have set up my boards, ports, and I/O device. When I...
3,285
Hi All, How can I configure the PLC to be a "Synchronized Time Slave" ? When I enable Time sync, it sets the PLC as the master by default...
19
14,606
Hi, I need to synchronize a PLC but I have no experience with this. I would like to know which are the common alternatives to achieve this and...
17
8,586
I want syn of two same 80 kw generators (Gen Model--KOHLER 80EFOZDJ) using PLC. The gen is electronics engine controlled by ECU (level 14, Deere &...
2,144
Hi sir. We are using Control logix redundant PLC system which supports only PTP time synchronization protocol but from DCS side we are receiving...
2,431
