PLC output problems
arbj
May 2011
mrt
61
I am using the Kinco PLC (type: K506-24DT), one of the outputs is shorted permanently, so even when made low the output is high at +24 VDC.
My query is can the PLC be still used ?, I actually don't need the output, but I am worried the problem could be carried over to other outputs or inputs.
Is there any possibility of such a thing happening ??
I believe the outputs and inputs are usually independent in a PLC, so technically no other ports should get defective, but there could be other underlying problems.
In any case I will run the unit (with all I/Os connected to loads) continuously for some time and see what else goes...
Please suggest your ideas...
thanks
a
Do you have a back up? That would be my top priority if I were to continuously run it with out fixing it.
I would look into that underlying problem as that is most definitely a issue.
Regardless, I would have a back up no matter what, its just asking for more problems.
I've never heard of Kinco, but I second the above post - get your hands on a spare as a matter of urgency and load it up with the program ready to go. You should* still be fine to use the PLC and it shouldn't* affect anything so long as you don't need that output, but you'd want to have a spare on standby just in case.
*as I said, I've never even heard of Kinco, so take my "should"s with a grain of salt :)
Leakage thru solid state output?
Do you see the +24 volts with load connected? What is the load?
I purchased a Click C0-02DD1-D plc because i was interested in learning about plcs. The model i purchased has sinking outputs and only 4 input, 4...
1,014
Hi guys, Im currently working on a project that involves cycling pieces manufactured at my work. Almost finished but I started having problems...
2,993
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
124
I have a project to control the speed of motor DC using PWM Output on PLC and when im on working i have a several trouble and of of them is the...
248
Hello, the PLC in question is 1769-L30ER. I have a local 4-20mA Analog Output module (1769-OF4CI), and also a remote ethernet PointIO analog...
408
