JR.Electrician
Hey Guys,
I am wondering if it is possible to wire an output from PLC to the start enable terminal (2) on the powerflex 40. as far as i can see in the manuals it seems you can only use a pushbutton wired directly to the drive. i would like to create logic in the plc and send and output to the drive to start enable without using a ethernet card on the drive.
