PLC Protocol
ssamir
Oct 2010
Karachi
Hi guys,
I am new to PLCs. We have CEGELEC CHANCE 2000 brand PLCs. These PLCs transmit data over thicknet LAN. Cogito is used for programming in PLC. Vendor gave some ISA slot based having AUI port nics. These nics are installed on PC and a program written on C language is run to capture the data. We dont know the protocol even. I want to know about the protocol of this PLC. There is no vendor support now.
1. What can be done in order to find out the protocol of PLC. 2. Secondly is it possible to change the protocol settings in PLC.
3. Generally what protocol normally PLC used to transmit the data.
4. How can I find the MAC address of this PLC. There is no information written on it.
I request all of you to share your expertise.
Thanks in advance.
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
348
Hello Guys, I have a packaging machine in the company that I work for that have 8 Omron VFDs (3G3MV ) that are controlled via Modbus with CJ1M...
650
Dear guys, I have a software that sends data to PLC using modbus. I want to connect my software with siemens plc, how can i do that?
19
4,729
Hello, this is a brand new task for me. I recently bought a particulate sensor and it communicates with UART protocol or I2C protocol. It came...
2,852
Hi, I had a client upgraded their system to use a set of redundant PLC system with GE PLC CPE400, and a Citect 8.0 (2016) SCADA to get data with...
1,451
