PLC Recipe Control
I went to the IO Configuration screen to figure it out, but same thing. Was hoping for something just on the plc itself to identify it. Since recipes address to the word level, I will need 40 addresses just for the string correct? (st:x.data[x])
Edit: Did a bit of reading on the ML 1500 LRP, do all processors come with 14k memory for program and data files plus 4k memory for just data? Then of course there is the 48k for data logging. If this is the case, that will be enough memory.
Something else I forget to ask, you can load and store from the same recipe file number right? One button to load the information, another to update it.
If you are looking at a running online program, then you have identified it. It wouldn't run with the wrong series selected.
Yes, and I think you have enough for 200 recipes. The question is will there ever be a need for more? If so, then maybe it would be smart to wait for enough money to buy a ControlLogix.
Hi guys, got one problem PLC model fp-xh c60t and HMI model TG765S-MT I've encountered an issue which is the recipe file went missing if i swtich...
88
Hello, I'm working with an already developed system that uses enhanced recipe on the HMI. I'm looking for the control word to allow the PLC to...
4,849
I'm looking for some advice on recipe backup on the AB CompactLogix line. I store my recipes in a UDT array of size 50. The UDT is relatively...
1,606
Good afternoon, I need to create a recipes display on the hmi ns8, to change the parameters of a servo and some strings . The PLC that im using is...
2,772
Using AB ControlLogix and C-More touch screen. My customer needs 50+ recipes each with 8 variables and 2 modifyers. They would like to use a Bar...
8,037
