PLC Rookie Intern Help?
No problem. Your program was fine for conversion, once the problem with the quirky OSR for the RSLogix was fixed. I was just showing another way to do it. I thought some of the instructions might be needed too, but I started deleting them one at a time using LogixPro, until I got down to the last post #29 version, and it still seemed to work okay. As you had originally, Rungs 001 through 007 could easily be combined into one rung with 6 branches.
Basic question, I'm having a hard time with terminology, "devise a circuit that will turn on a light to indicate that a momentary input signal...
42
11,622
PLC not receiving voltage, display screen and i/o not lighting up. power supply receiving 115 volts ac. When you remove plc wire from power supply...
2,165
Hello, I am a plc engineer and I have a job to do in the NIGERIA 25000 TON GRAIN SILOS STORAGE CONTROL PANEL. A problem where the panel is not...
120
GitHub Link: Open Industry Project This is a side project I've been working on for some time. The goal is to provide an open platform for...
125
Dear All, Currently i'm working with Endress Hauser flowmeter and AB PLC and try to integrate with 2 items. Flow meter spec using is Promass...
167
