PLC S7 1200 fail to go online
Kratos15
Sep 2023
Ho Chi Minh
Hi. I’m trying to upload program from existing PLC S7-1200. Create new project in TIA v15.1 then upload. After upload successfully, go online but received some notice as “ online and offline difference” and Difference in lower-level component”. Please help to solve. Thanks
When I see this it is usually because the firmware version that you can set in TIA doesn't exactly match the firmware in the PLC. So long as the firmware in the PLC is in the same version ( 2,3 or 4) and has a higher number than TIA, then I haven't ever seen it cause a problem. They update PLC firmware more often than TIA software.
Thanks for your reply. I’m not familiar with Siemens PLC. Please advice how to set the firmware in TIA to match with PLC firmware?
To upload a running PLC project to PC (TIA Portal), you need:
1. Create a NEW PROJECT,
2. Then in PROJECT VIEW select:
Online->Upload device as new station (hardware and software)...
3. Select PLC and upload,
4. Go "online".
4. Go "online".
I did same as your instruction and upload successfully but can’t go online.
Create a new project, add hardware, select s7-1200, then open that tree and select ‘unspecified s1200 CPU.
A yellow dialog box should pop up with ‘detect’ underlined, detect and it’ll upload the specific CPU hardware.
Then go online, and upload and it’ll bring the blocks up as well as the rest of the hardware.
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
70
44
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
109
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
3,040
Hello members, I have Siemens S7-1200 PLC (CPU 1214C AC/DC/Rly version 3.0) and I want to get backup from it. I know how the procedure works. I...
154
