PLC Schneider M340 and Siemens S7
baselch0
Jul 2010
Basel
27
Hi all,
I'm facing a problem using UnityPro S software for PLC M340 Schneider.
I defined a double word in DINT format (%MW100) and I'd like to move the value to an 32 digital output card place on slot 8.
In ST (structured text) language i can do this:
%Q0.8.1:=%MW100.1;
%Q0.8.2:=%MW100.2;
%Q0.8.3:=%MW100.3;
etc. etc. etc
Is there an instruction or other way for transfert the value of %MW100 to the 32 digital output without write one by one??
In siemens for example using AWL code is very easy:
L MW100
T AW80
L MW101
T AW81
But using different way in Schneider the system said that address of the digital output card is not defined.
In the ST code (using also a single word of the double word)
%QW0.8.1=%MW100; (wrong mode because the %QW.....is refer to an analog output not set in the hardware configuration).
Thanks in advance
This is possible, if you use COPY_ARDINT_AREBOOL block on unity.
You have to use array variables for this and also choose setting "Allow Dynamic arrays" from project settings.
so i have an isssue where if the serial port of an M340 plc disconnect from the screen it would retain the values of the variables being sent...
917
I need to establish communication between Schneider M340 and S7-1500 PLC. I am using gateway converter for MODBUS TCP TO PROFINET protocol...
2,992
I have a system installed in my company which have M340 PLC and it has a program which is used toh turn lights on and off. I am attaching program...
3,380
Hello Everyone, I have one task which involves migration of Premium PLC CPU P57104M to M340 PLC. My senior have given me converted program from...
3,911
Hi guys, I am using BMXP341000 processor and a NOC04001 Communication module. I have seen some you tube videos where people configuring the...
2,638
