Plc Siemens S5 115u Cpu943
abuelfun
Apr 2004
khartoum
30
HELLO
FRIENDS
IN ERROR DIAGNOSTICS ON CPU THERE IS A SELECTOR SWITCH RN/ST WITH TWO INDICATORS GREEN/RED .
MY QUESTION WHAT IS THE DIFFERENCE BETWEEN LED FLASHING AND LED FLICKERING
BEST REGARDS
Please be more specific:
  • which of the two LEDs are you talking about (I suppose it's the red one)
  • define flashing
  • define flickering
Kind regards,
PLC SIEMENS S5 115U CPU 943
HELLO
jvdcande
GOOD MORNING
THANK YOU FOR YOUR REPLY , YES AS YOU SUPPOSE I MEAN THE RED LED.
MY QUESTION THAT :
1. WHAT IS MEANT BY FLASHING (IS THAT MEAN LIGHT UP CONTINUOUSLY OR BLINKING ).
2. FLICKERING WHAT IS MEANT CONTINUOUSLY LIGHT UP OR BLINKING .
N.B.
THE RED LED I MENTIONED IS THE STOP INDICATOR OF THE CPU.
MEANLY MY PROBLEM IS HAT I CONFUSED BETWEEN FLASHING AND FLICKERING.
BEST REGARDS
Flash Rate?
Hello abuelfun
Could you be asking about the flash rate (frequency) of the LED indicators?
Lets say a flash rate of .5 seconds on and .5 seconds off would represent the LED flashing.
Flickering LED could be the LED flash rate is .05 seconds on and .05 seconds off.
This would be so fast that the LED would appear to dim and brighten or even just appear to be dim.
Hope this Helps
Dan
Hi, I have tried with the cable IBH S5-USB-Adaptor, communicate with the PLC above, but I can not! The response of the technical assistance of...
3,667
Hi All, I am a Plant Engineer of a Cement grinding and packing factory here in Lae, Papua New Guinea. I have a MEchanical Engineering background...
4,670
Hi, I try to connect Siemens text panel TD17 to S5-115U plc. For PLC to communicate with S5-115U CPU, I need the standard function block and I...
2,141
Hello friends I have a plc siemens S5 115u cpu 943 B machine was runing smoothly and stopped for break ,but when restarted the following...
8,853
Hello All, Does anyone know what software and cable is required to get online to a Siemens S5 115U PLC? I need to be able to Upload/Download and...
17,202
