PLC SIMATIC S5 115U CPU 943B Want to on
Nov 2021
Oman
Hello Dear,
I am using a PLC SIMATIC S5
115U CPU 943B
my problem that there is no output on CPU (943 B)
⚫️RUN
STOP
🔘RUN
🔘STOP
🔘QVZ
🔘ZYK
🔘BASP
⚫️NR
RE
OR
I Restart by button ⚫️NR/ RE /OR but it’s not on. Only Red light blinking in RUN .
In the Display showing
[ pc- restart running ]
It is possible to perform an overall reset on the CPU. This will erase the RAM memory and copy the contents of the EPROM back to the RAM.
***It is recommended to try to upload from the CPU before trying the overall reset procedure below if you have STEP 5 software and a transferl cable.***
Set the top switch to STOP.
Set the bottom switch for "Default/Overall Reset" to the "OR" position and hold it in this position (if the switch is not held in position it will automatically spring back to the "RE" position).
While you hold down the switch for "Default/Overall Reset" in the "OR" position:
Switch the CPU mode selector twice from "ST" to "RN".
The STOP LED will momentarily go off.
Release the switch for "Default/Overall Reset".
The switch automatically springs back to the "RE" position.
The internal program memory and any RAM submodule (plugged into the CPU 941/CPU 942) are now "overall reset".
After Overall Reset, the CPU automatically tests your internal program memory; in the event of a fault, the STOP LED flickers.
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
I have new Siemens PLC / Simatic S7-1200 Need software download to use the PLC Please advise Thanks Wally
2,247
643
Hi guys, Could i connect simatic WinCC runtime with Micrologix 1400 PLC via Modbus?
1,245
Hi everyone, I have Siemens S7-1200 1214C AC/DC/Rly CPU with CM 1241 Rs232 module and Enfora GSM 1208. Help me how to send sms using PLC. Thanks.
2,016
