PLC Simulation Program
mmarch
Oct 2005
Akron, Ohio
21
I recently took my first PLC class and although I learned the basics, I had to share programming time with three other students. I saw an ad on the internet for a PLC simulation program and bought it. One major limitation of studying PLC programming this way is there is nobody to ask questions to. Thats why this site was a great discovery. I am working on a program in which there is a standard six-light stop light (red, yellow, & green for each of the two controlled directions). I have almost completed this program, which is only approx. ten rungs long, but I have hit a snag that I need help getting past. I know nobody that can help me with this. Is there anyone out there that I could fax a copy of my program to, who might be able to give me some advice? I have spent hours trying to complete this to no avail. Any help would be greatly appreciated.
Try creating a pdf and post it and ask your question. Everyone loves the traffic light application.
There are many free PDF engines on the web, here's the one I use: http://www.primopdf.com/
Once you have a PDF engine installed, it will be listed as one of your system printers.
Then, when you print out your program, just pick the PDF printer, the output will be a file, then post the file on the forum.
Good luck,
Ken
logo applications
Hi !
I am still trying to program this logo .
Is anyone familiar with the logo who can offer some help.
Lancie did put me on a path to a solution but more help is needed.
Heres the problem :
I need to program the logo to monitor a device whose output s a varying voltage I need to output this value as a reading in degrees i.e. convert or scale the voltage reading so it represents a value in degrees.
I know I will need to somehow store a range of values in degrees or equivalent volt-degrees and compare the input to these values then if value at the input equal stored value output this value.
I must use the logo to implement this no other option.
I would appreciate your help please !🤞🏻:confused:
Whish1, you're probably stuck. Why 'must use Logo, no other option'??? Why do people think a programmable relay is a full-blown controller. You cannot get high functionality like a PLC for the price of a Logo. Spend the couple extra bucks. Isn't the time you'll save worth at least that?
Hi folks, Does anyone know companies that create realistic virtual PLC training programs we could use to train our technicians. We are currently...
2,344
82
Hi Any one here please helpmein simulation of s7 300 plc program with factory io. how to connect. plcsim 5 doesnot have option of s7 300 ..:
1,014
Hi all, I'm having a bit of difficulty when it comes to the final question of my assignment, and wondered if anybody could shine some light on it...
1,157
GitHub Link: https://github.com/Automation-Standard/Open-Industry-Project This is a little side project I've been working on that I felt would be...
3,426
