PLC Simulation
codedRed
Jan 2019
Nebraska
30
Our vendor just offered me a demo of FT Logix Echo and I'm really interested in how you guys apply simulation software. My understanding is I can simulate an MER file and an ACD file on my PC. But if you're in a situation where the machine isn't present or is in design phase - how are simulating the machine actually running with I/O? My first though is that you need to setup your I/O on timers or sequencing - that wouldn't be included in the commissioned program but was created for the purpose of simulation only.. which could be a lot of work.
Just curious how other people use simulation software in their design phase.
I never use the simulator to do the sim of the I/O (did many years ago on a system called prosis for Siemens but that allowed you to write programs in pascal so really good), What I do is have a block that maps inputs to internals & internals to outputs called I_O_Map, just don't call it until actual I/O is required, then I write simulation blocks in the PLC using timers etc. that write to the mapped bits, this makes it easy to monitor & test, I even do that on a real PLC & of course you do not need the actual I/O.
82
Hi Any one here please helpmein simulation of s7 300 plc program with factory io. how to connect. plcsim 5 doesnot have option of s7 300 ..:
1,012
Hi all, I'm having a bit of difficulty when it comes to the final question of my assignment, and wondered if anybody could shine some light on it...
1,157
GitHub Link: https://github.com/Automation-Standard/Open-Industry-Project This is a little side project I've been working on that I felt would be...
3,426
Hi all, I am just looking for other more experienced opinions on how programmers use simulation to help fault find errors in their PLC program...
2,418
